L_Jonez Mk2 rebuild
Re: L_Jonez Mk2 rebuild
Postby l_jonez » Sat Jan 28, 2017 7:15 pm
Made a small bit of progress
Turbo flange arrived
As well as a super small 100mm denso alternator
Also refitted the rear arms, along with all new brake components. The only "old" part is the back plates.
l_jonez
Postby l_jonez » Thu Feb 02, 2017 1:14 am
Done a bit more today
One of my biggest goals is not to modify the car in anyway that can't be undone so when it came to the fuel lines joining up to the tank I didn't want to modify the floor pan. Instead I've decided to run the lines along the top of the tank and then down the side.
And fuel lines in place along with filter (need to install bracket)
Sorry for the rubbish pic but being upside down doesn't really help.
Hopefully when the car is back to normal ride height there will still be plenty of clearance between the lines and coilover, if not then the tank can slide over an inch or 2
l_jonez
Postby l_jonez » Mon Jun 26, 2017 5:16 pm
Right then it's been a long time since the last post and to be honest pretty much nothing has happened :(
A few little things like the fuel lines are now clipped in place the tank is mounted but now 30mm further towards the drivers side to give extra clearance. But the main bit of progress is the inlet manifold I was going to use a Toyota Corolla manifold welded into the Micra flange ( photo on last page) but I wasn't very happy with how the runners lined up and it made the injector clearance very tight so I've spent a fair bit of time online researching various engines bore spacing.
I ended up taking a punt on a manifold from a Suzuki Alto, when it came it was quickly sized up against a Micra gasket an it's damn close
So off came the flange and it was tried in place, the off set to the passenger side helps with clearance
It's pretty tall but lower than the master cylinder and the bonnet shuts thank God
As it stands now it's just tacked together
This manifold also leaves plenty of room for the injectors
l_jonez
Postby l_jonez » Wed Jul 12, 2017 9:50 pm
l_jonez
Postby Jin » Sat Jul 15, 2017 6:24 pm
Looks like your having photobucket problems too
http://easywider.co.uk/ universal flexible wheel arch extensions
Postby l_jonez » Sat Jul 15, 2017 8:36 pm
Jin wrote:Looks like your having photobucket problems too
Yep, I doubt I'll be uploading them all again. I'll wait for the dust to settle then decide where to start hosting pics again
l_jonez
Postby fozzza » Sun Jul 16, 2017 10:28 am
I'm no I T expert but are photobucket starting to play silly buggers :?:
Postby l_jonez » Sun Jul 16, 2017 1:22 pm
They have changed their t&C's and now want $399 to share photos to forums etc. I'm not paying that!
l_jonez
Postby Geoff Butcher » Sat Aug 12, 2017 8:14 pm
So what is now the favoured way to upload photos?
BTW I tried the forum search for 'photobucket' but it said it's too common a word and wouldn't do it... :?
Postby l_jonez » Sun Aug 13, 2017 10:20 pm
I'll be honest I haven't looked and I've not really done much on the build that's worthy of posting pictures
l_jonez
