2 days to bloody align the bonnet!
Since I got the car the bonnet has never fitted well although I did improve it initially.
However the drivers side front edge was always 3-4mm above the wing even at maximum adjustment I had even tried bending the hinge.
Time for more drastic measures.
Prior to removing the hinge I drew through the existing holes to gauge what was done beforehand - quite a lot it would seem in terms of butchering holes in fiberglass, so not wanting to remove even more by elongating the holes i cut 10mm out the hinge itself so to bring the bonnet down and allow the hinge a bit of upward movement instead of being at max adjustment.
With that sorted I made some new buffers to raise the mid section of the bonnet (it's almost like it's tried to straighten itself out over the years) and elongated the mounting holes for the catch and I've got panel gaps even Audi would be proud of
