Hi all, sorry I’ve not been on for so long, rest assured I’ve not been taking it easy and skiving off, far from it, I’ve just been up to my ears in it.
So to begin with the lasts jobs, the seats – well the mounting of.
I had noticed the seat sub frames had become – shall we say a tad rusty,
Further investigation showed the seat to not actually be attached to the floor in many places
The fixing that pass through the floor didn’t look too clever either
So I got out my trusty socket set and set about undoing the floor bolts, unfortunately all 4 were so corroded the heads were unidentifiable, there was no shape to grip onto,
I couldn’t chisel them off either for risk of damaging the floor so my only option was to hold a hacksaw blade between my fingertips and slowly slice the heads off – about as much fun as finding worms in your ice cream
The outer 2 were the worst probably due to being In the firing line from the wheel so I had hoped the inner 2 would at least surrender to the ,mole grips, thankfully one had the decency to shear in half
which just left one but by his point I was well and truly pi££ed off so I go the angry grinder out and lopped his head off as this bolt passed through the exhaust heat shield I felt it a safe bet.
Seat out to fully appreciate the horrors
For a fiberglass car this is very rusty, even the carpet is rusty
So new sub frames were needed, I didn’t like the original design since you’ve technically only got point contact front and rear, not much to spread the load down the floor, so I got hold of some galvanised cable conduit, its C section so easy to get to the fixings and 2.5mm thick so massively strong,
plan was to just bolt in place of the old sub frames and be happily on my way, but things never go to plan.
The first attempt to do just that saw the floor show up to not be totally flat at the original fixings locations,
this is because the matting has been laid up to join the inner sills to the floor and the centre tunnel also intrudes into this area, not by much ad no problem for the flexible original sub frames but there is no give in the new ones so the runners just jammed solid
So seat back out and a new flat location identified for the runners, approx. 40mm in from the originals
now the sub frames didn’t line up with the seat so I made some plates out of 6mm thick aluminium to allow the seat to fit to that, this is a good move since I don’t want to keep these seats for much longer and I now have a universal platform to mount the new seats onto
the end result
The original seat mount holes have been plugged up with M6 flange head stainless bolts and the new seat mounted down with M8 stainless flange bolts and nuts (M6 just doesn’t seem enough really) and the C section sub frames beaded down on a bead of polyurethane to prevent and moisture getting in between and to spread the load against and slight unevenness on the floor itself
Then I had the pleasure of doing it all over again on the driver’s side, it’s all done now though and now I can drive the car safe in the knowledge my arse is safe with the added bonus I’ve been able to rip most of the carpet out now so the car smells slightly less like a tramps dog inside so a win win situation, for now I’m just rocking the no carpet race car look with a set of not very tailored mats from that well known car accessory emporium – ASDA.
At least it will be easier to trace leaks.
That’s all for now, that’s about a weeks’ worth of work there
More to come soon I promise
Stay tuned when I’ll be finding out how many attempts I can have to undo a seat belt bolt before I admit defeat and fiberglass over it and how many different methods of joining wires is it possible to cram into one 8” length?, is 4 enough or can we find more?
