Postby Jon » Tue Apr 07, 2020 6:50 pm
That's looking good Mr Bounce. I put an RC40 twin box centre exit system on my Mk2. It sounds good but isn't too noisy.
Jon
Postby Crowmann » Wed Apr 08, 2020 2:32 pm
Both look good, great thread BTW - Jon your centre box looks low I guess not too low.
My Mk3 has pretty much no center box which means nothing to get trashed but a lot of noise.
Crowmann
Postby Jon » Wed Apr 08, 2020 6:10 pm
Crowmann - I've not had any problems with ground clearance.
Jon
Postby MrBounce » Sat Apr 11, 2020 3:20 pm
Just a small update this afternoon. Having looked carefully at what the best way forward would be, it appeared that it would be a simple case of chopping the rear box away from the pipe, and popping in an extension of roughly 6 inches. Obviously I would need to work on the angles of the pipes involved, but all in all it's a relatively simple task. Simple if you have a lift and are proficient at welding. I have a single garage and an old SIP welder donated by a friend. I can weld, just not very well. Nevermind, a tack to hold it in place will do until I can get it done properly.
I made a note of where I wanted to cut using a roll of electrical tape, and put the angry saw to work. It made short work of going straight through and I tidied it up with a file. I then had a look around the garage to see what I could use to bridge the gap. Whilst I don't have a vast amount of exhaust pipes dotted around the place I did have two bits that might possibly be useful. First was a Mini big-bore centre pipe. Unfortunately I had to reject this as 1) it was 2" ID pipe and therefore bigger than the 1 3/4" on the RC40 but also 2) it was stainless - I've never welded stainless before but I am pretty sure you need different wire otherwise you run into problems. The other option was a random piece of pipe which was in the masses of spares that came with the car when I got it. I had put this to one side because it "might be useful". I almost threw it out when we moved but that "just in case" thought was a good one. 1 3/4" internal diameter too. I know this means I would need to get it welded properly but I have a plan for that.
Out came the angry saw again and I cut said bit of pipe to size. I then spent a while cleaning it on the wire wheel because it had a LOT of surface rust. A bit more measuring up and I put it in the vice. I got the welder out and put a splattery tack weld on it to hold it in place. And that's where I left it.
Angry saw cuts brand new exhaust. Evil thing...
Offcut from pipe I'd kept "just in case". Needed a LOT of cleaning.
Extension tacked in place (badly) until I can get it properly welded up. No I am not showing you my dreadful welding.
Postby MrBounce » Tue Apr 14, 2020 8:51 pm
Another quick update. The back end of the garage was in an utter state so I spent most of this afternoon cleaning it up. I had kept getting my feet tangled up in stuff when I had my head under the rear of the car sorting exhaust stuff, so it was about time. Whilst doing this I came across 2 things: the first was a smaller piece of steel pipe which I cleaned up on the wire wheel and will use for practicing my welding on. The second was the bumpers for this car up in the rafters.
I decided that as I didn't want to do exhaust stuff today, I would take a look at the rear bumper. I had decided to cut a hole in this for the foglight - I have a round one to go in. In my haste I had carefully measured twice, then happily picked up the wrong size holesaw. Thus said hole was WAY too big for the foglight. This had annoyed me, so I had taken it out on the bumpers by putting them to one side. This was over 2 years ago - and we'd moved house since then, hence why the bumpers were up in the rafters - I was obviously still irritated by the sight of them!
So, what to do with an oversized hole? Answer - fill it in! Out came the chopped strand mat and the resin. I made a cardboard square to go over the outside of the hole, then used gaffer tape to hold this in place. A decent amount of resin and matting went on the rear of the bumper and a couple of hours later it's as solid as a (plastic) rock. Needs a bit of a sand but most of it will be getting chopped out again, hopefully this time with the right sized holesaw...
Filling the hole with resin and bits of chopped strand matting.
And the finished result before I get creative, this time more accurately...
Postby MrBounce » Thu Apr 16, 2020 12:01 pm
Once again concentrating on the bumpers, specifically the rear one, it was time to smooth off the area I had filled in then mark it up for redrilling. Or making a new big hole if you prefer. Smoothing the area was easily taken care of with some 180 grit, and then it was time to mark out where to drill. Turns out that when I made the initial hole all those years ago it wasn't even central. Guess I had been tired - at least that's the excuse I am sticking with... Anyway, after an exploratory pilot hole out came the correctly sized holesaw and a nice foglight aperture appeared. I need to do some more sanding and a bit of filler to tidy, then it'll be time to trial fit them and to sort out the mountings, before I paint them.
And this brought forth a new potential issue - how to hang them when painting. Although very light, they're extremely unwieldy items and can't be hung anywhere that I would be able to get a good coat of paint on every extreme. What I needed was a stand. I had a quick look around the garage and had a rummage through my scrap wood pile. I am glad that I hold on to this sort of thing as it comes in very handy from time to time. A bit of sawing, drilling and screwing (matron!) got me a half decent stand that is drilled to mount either bumper using the captive nuts on the brackets I had fibreglassed in. Now all I have to do is prepare the things for paint...
Bumper sanded off and marked for new pilot hole for the foglight.
As if by magic, a hole appeared
And the stand I made from wood I had lying around. Scruffy but effective.
Postby dusz » Thu Apr 16, 2020 3:10 pm
Thought you might be taking up gymnastics - the beam!
dusz
Postby MrBounce » Thu Apr 16, 2020 3:51 pm
dusz wrote:Thought you might be taking up gymnastics - the beam!
Hell no! I'd get an injury just looking at it :lol:
So what's this? A second entry in less than a day?! Wonders will never cease. I thought I'd start sanding the rear bumper to ready it for paint and almost immediately stopped. Yes, I know I hate sanding, but I had obviously never paid much attention to its condition - there were quite a few tiny cracks. Make that a LOT. Having done quite a bit of fibreglassing now, I knew that there was no likelihood of these being simply sanded away. It was time for the Dremel. Again. I REALLY didn't want to do this as I felt I was getting somewhere, but I knew they'd never go away unless I did it properly.
So, under the watchful supervision of both Moneypenny and Daisy, I spent quite a while with the grinding wheel getting rid of all the little delights before filling them in with P40. Much sanding will follow. Oh joy...
LOTS of these little bar stewards. Grrr.
Dremel grinds!!
Moneypenny and Daisy supervising.
P40 to sort it properly. Sanding awaits...
Postby MrBounce » Sat Apr 18, 2020 4:57 pm
The trouble with having a rare project car (this one is one of 57 when made when they were new - I somehow doubt there's that many now...) is the issue of some parts. I had a good look at the rear bumper this afternoon. If this was not a rare car, the bumper would be condemned. But that's not going to happen since I cannot get one. At some stage in its life it had been brush painted with some sort of awful thick gloopy paint. Much sanding had revealed the bumper looked in fairly good condition. Sadly, I realised that after a much closer inspection, having cleaned it down with some white spirit, that this was not the case. There were a LOT of hairline cracks and even more "fish eyes" where air had been trapped under the top layer.
I had three options here. 1) Run without a rear bumper. Nope, looks silly and would mess up the rear of the car if I tried blending in the gap. 2) Throw it away and get another one. Also nope. I have never even seen another spare bumper. 3) Grind down and repair what I have. Again. Even though I REALLY hate sanding and bodywork, this was the best option.
So out came my friend the Dremel. I ground out the numerous cracks using the slitting tool, then put a grinding wheel on and took the top surface down in places until there were no more holes from the air pockets of the fish eyes. I built it back up with P40 ready to sand down. Again. Still, I got to use my bumper stand I'd built...
Solution? If you're going to buy a plastic Mini-based car, get one in better nick. Or one that is a more common example.
Did I mention I hate sanding??
Cracks, cracks, bleeping everywhere...
Large areas ground out. It was nasty.
P40 applied. Grudgingly.
Postby Tich731 » Sat Apr 18, 2020 7:53 pm
"Been there; done it; got the tee-shirt."
Seriously, keep going and eventually you will have a presentable finish.
Great thread - I am always checking for your latest posts.
1981 MkII Midas Silver
Tich731
