MIDAS MkII - Competition Build
After a couple of false starts and advertising it for sale, I have decided to prep my MIDAS Bronze for Competition use.
Like any kitcar or car that has never been raced it won't be straight forward but I bought the car because i beleived it had potential for competition use and was Mini based.
As was alluded to in other threads, there has been some thought gone into this and it has now started.
I delivered the car to Alistair at Alternative cars to undertake the first modifications. It was a pleasure to meet Alistair who is equally enthusiastic about the project and immediately offered some incitful advice as to a way forward.
The Mods on the car thus far will be:
- Dropping the drivers floor for better seating position (leaving the passenger as have decided that I won't be able to rally it due to competition equipment limitations).
- Undertray for rear (Alistair has them) and he is looking at making a front undertray.
- Lightweight door cards to replace the standard ones (to be made by Alistair as he is considering them as an option for the car).
- Adjustable rear camber and toe for the rear beam.
- Replacing all glass bar front screen with perspex (All glass will be for sale - including rear screen).
- possible replacement of front shock setup with coilovers with adjustable platforms for corner weighting.
Work undertaken thus far:
- Replacement of front tiebars and bottom arms with HD adjustable ones.
- Replaced front and rear shocks.
- Interior completely stripped for lightness (dashboard still to come out and will be available).
- Minifins on the rear.
Additional work to be done:
I used to race an MG Metro and when it gave up due to a rusty shell I kept a number of parts:
- Fit full race MG Metro Morspeed engine with miglia dog box. (Having checked the bulkhead i will be using a 45 weber as well which is what the head was ported for).
- Fit MG Metro turbo breaks (including running additional brakelines for 4 pots).
Additional competition Mods:
- Run all lines internally.
- Move battery to rear.
- Fit rollcage - challenge to come.
- Fit appropriate competition seat - another challenge.
- Possible fitting of a floor mounted pedal box to offset race seat position.
That is probably enough for now apart from the only worry I have is removing the sunroof as it will be expensive to do and may require another shell instead.
So a small list of jobs none of which are insurmountable and will be done in stages as budget permits - The help and encouragement of Alistair from Alternative Cars will be invaluable to the project and I will thank him up front for embracing the project.
