AVONBAR
Re: AVONBAR
Postby axshack » Fri Feb 12, 2016 5:06 pm
Jin wrote:Is that all dynoed up and ready to go?
Looks awesome
to quote the builder, it went together like a dream...which gives me a warm feeling that it is going to run like a sewing machine !
after running in for 1000miles, then I will take it to my nearest rolling road and get them to work their magic on it, after that, I think I will have a very good power unit indeed ! :D
Re: AVONBAR
Postby axshack » Fri Feb 19, 2016 8:21 pm
Well, I picked up the engine today. Must say it looks extremely tasty. Should be in the car in a couple of weeks or so, depending on how the coil over conversion goes. Have had explicit running in instructions from Mr.Avonbar before I take it to Neil Slark for a rolling road setup later this year. :D
Re: AVONBAR
Postby axshack » Fri Apr 08, 2016 3:25 pm
Just to round this thread off.
I have run the engine for 128 miles so far and it is performing very well.
Only 900 miles to go to complete the running in period !! :D
Dave
Re: AVONBAR
Postby Hans Efde » Fri Apr 08, 2016 4:15 pm
Congrats on the upgrade, you can't get more smiles per mile than this. Have fun.
Re: AVONBAR
Postby axshack » Tue May 17, 2016 5:11 pm
Having a real problem getting this engine to run with the Weber carb !!
It looks like there is a misfire on No.4 cylinder, which needs sorting out ASAP !!
Re: AVONBAR
Postby Geoff Butcher » Tue May 17, 2016 8:09 pm
Is the cylinder sparking? Have you tried swapping the plugs around? Valve clearances OK? Manifold air leak?
Re: AVONBAR
Postby axshack » Wed May 18, 2016 11:07 am
Geoff Butcher wrote:Is the cylinder sparking? Have you tried swapping the plugs around? Valve clearances OK? Manifold air leak?
checking all these today Geoff
Re: AVONBAR
Postby axshack » Wed May 18, 2016 5:08 pm
BTW! does anybody know what pressure the fuel should be for the 45DCOE?
I think I have mine set too high so want to get it right - trying to eliminate any and all potential reasons for the carb to not run properly !! :)
Cheeers
Dave
Re: AVONBAR
Postby l_jonez » Wed May 18, 2016 5:11 pm
2-3psi if I remember correctly
l_jonez
Re: AVONBAR
Postby Jvr19630 » Wed May 18, 2016 6:22 pm
Yes, 2-3 psi sounds right
Also be careful of bore washing if too much fuel is going in.
Are you still running the engine in ?
Jvr19630
Return to A series engined projects
Users browsing this forum: No registered users and 7 guests
