AVONBAR
Re: AVONBAR
Postby axshack » Thu May 19, 2016 1:00 pm
yes, still running the engine in.
Took the weber off today, replaced the HIF44....still need to sort the mixtures out, but have a new, richer needle in now, so hopefully that will fix it leaning out.
So going to finish the running in with the SU then go to a rolling road and fit the weber. Well that is the plan, we will see if it comes to fruition !! :)
Re: AVONBAR
Postby kelvink » Thu May 19, 2016 1:27 pm
Given where you are located in the country why not go along to DEWS sometime and have a chat there, or indeed speak to Adrian Dodds who gave a superb talk at the MOC Pitch last year at Stoneleigh on tuning the A Series
http://www.bjautobits.co.uk/dews.htm
Re: AVONBAR
Postby axshack » Thu May 19, 2016 1:54 pm
thanks Kelvink, will do
I can report that the SU is running ok, and the richer needle seems to have cured the leaning out problem under load.
Meanwhile, going to get the weber surveyed, as I think that there is a problem with one of the barrels.
D
Re: AVONBAR
Postby Hans Efde » Thu May 19, 2016 6:24 pm
Maybe it's possible to fit a Lambda probe kit. Almost all new exhausts have plugs you can take out and install a Lambda probe in. With a dial in the cockpit you can see how the engine is running. Saves a lot of guessing. I paid around 200 euro for my kit and made it possible grinding a needle specific for my engine.
Return to A series engined projects
