A+ engine identification
Postby DavidL » Thu Jan 17, 2013 11:55 am
Is there a way of telling whether an A+ engine is a genuine MG one?
Can you interpret anything meaningful about an engine's origin from the engine number?
Failing that, I'd assume that the engine number would at least give you an idea of its age. If it does, I'd guess that it's not a straightforward "89" in the code to represent 1989. Can anyone throw any light on this?
Sadly, my engine (no sign of red paint on the block) is missing the engine number plaque, which seems to be all too common.
Re: A+ engine identification
Postby Hans Efde » Thu Jan 17, 2013 12:14 pm
I recall it is mentioned in the Haynes manual. Else several websites give detailed info:
http://www.calverst.com/articles/Eng-En ... n_data.htm
Postby Stuart » Thu Jan 17, 2013 12:15 pm
Guessworks has an engine decoder on his website
http://www.guess-works.com/Tech/engine.htm
another list here http://www.calverst.com/articles/Eng-en ... n_data.htm
and some pointers here for engines without a number http://new.minimania.com/article/1801/M ... Power_Unit
edit. Hans beat me to it
Postby DavidL » Thu Jan 17, 2013 7:03 pm
Thanks both. A lot of useful info there! :)
(edit) It appears that my engine block actually is an A+, despite my misgivings - no bridging plate for the alternator mount, and I think there's only one bolt on the distributor clamp. Odd that, I thought all the 1275cc A+ blocks were red, but this one also has a blue painted cylinder head. Maybe the engine builder thought the red block would clash with the blue head. ;)
Return to Engine conversions
