EV Conversion for a Mk3 Coupe
Re: EV Conversion for a Mk3 Coupe
Postby manifold » Wed Oct 22, 2025 3:05 pm
Opened up the BMW sp51 battery box today. Need to sort out some PPE inc rubber gloves before braking down the battery packs. Looks to be 5 packs. 2 on one side and 3 on the other, with one mounted side on.
Postby manifold » Sun Oct 26, 2025 9:46 pm
Been on a bit of a spending spree this weekend ordering a few items to build out the contactor high voltage junction box (or HVJB).
References have been taken from https://openinverter.org/
The HVJB is a circuit in a box which is controlled by the ignition key to open up the high voltage circuit contactors on positive and negative to energise the electric motors inverter - basically a few big relays, plus something called a precharge circuit. The contactors I will be using are Kilovac EV200HAANAs. I think Kilovac EV200AAANA will also work along with Duracool and Gigavac GV200.
The precharge circuit energises the inverter on the positive circuit with a 100watt 100 ohm resister, along with the negative contactor just before the positive contactor closes. in milliseconds, once the main positive contactor is switched on (closes) the precharge positive circuit is then disabled (opens). The reason for this is to avoid wrecking the inverter with a high rush of energy and also to avoid wrecking the contactors by welding them shut with sparks. All EVs have this kind of circuit utilised in one form or another. The positive contactor is also protected by a 350A 600+ volt fuse. The contactors are a special vacuum sealed component which are filled and sealed with hydrogen which retards the sparks from the contactors.
The is also an opportunity to fit an Isabellenhütte IVT-S-1K-U3-I-CAN2-12/24 shunt to measure energy current. (yet to be ordered as its a pricey item).
None of this stuff is cheap unfortunately. The HVJB box will probably cost more than the motor and the inverter but is a critical component.
NOTE: The voltages are high on this stuff so care needs to be taken. Eg planning and thoughts around PPE. 300-400 volts and upto 250 - 300 amps. So please bear that in mind.
Here is an example of the HVJB box before power into the box and out to the inverter are added (with compression fittings).
Here is another one:
I will be building something similar, but I will also be putting it inside a metal box for safety reasons.
Postby manifold » Sun Oct 26, 2025 10:49 pm
Not a route I am going down but apparently the Nissan Leaf EV motor and the Mitsubishi PHEV (and Toyota Prius) may share similar internal components. Power output is good on the Leaf motor for between 147-215hp dependent on version. Nissan spent £1 billion investment developing the Leaf... Might also be a fit for a Midas Mk3. Here are some pics with the Leaf motor, differential unit and inverter on top:
Postby madmax83 » Mon Oct 27, 2025 9:21 am
Your battery is certified to R100 03 series. What does that mean? You buy yourself 5mins to get out of the car safely if a runaway occurs. Just showing off now because that regulation makes up most of my everyday work 8-)
Did you ever get any information about what happened to the car and what the battery had experienced? Have you been able to get any read-outs from the battery to understand what condition it is in? It's a good idea if you download the regulation to get some tips surrounding good installation guidelines.
[/https://unece.org/transport/documents/2022/03/standards/regulation-no-100-rev3]
madmax83
Postby manifold » Mon Oct 27, 2025 10:44 am
The car the batteries came from had a front end head on smash. The batteries are mounted in this car under the rear seats where the standard ICE cars fuel tank sits. I saw the pictures from the crashed car. It is a 2025 BMW 33OE Touring Estate. I aim to be reading the data from the CAN and will probably be making up a BMS for it to work out condition of batteries generally. The date stamp of the battery box is 03/2025 so I am not too concerned about the battery condition. The batteries can store for years if the contactors are open which they are if there is no power to the HVJB. I will be redistributing and mounting the batteries in the rear of the car behind the seats. In an insulated, metal, self made battery box. Will take a read on the guideline spec you sent though.
Postby manifold » Mon Nov 03, 2025 12:51 pm
As part of the my project collection process I was looking for some kilovac ev200 contactors on ebay the other day and managed to bag a nice schneider electric metal contactor box stuffed with half a dozen or so kilovacs, standoffs, fuses and glands from a UK built EV bus. A bit overkill number of contactors for my project but good for me to have a few spares. The EV bus (as in autobus) had 4 battery banks apparently.
Pretty pleased with the box (with lockable key). Very well made unit.
I will be using 3 contacts at moment. 1 each for + and - battery terminals to inverter plus an additional one for the precharge circuit on + to inverter (with a 100 ohm arcon resister). I will probably pop another couple of kilovac contactors in for the HVDC to LVDC charging circuit though.
Postby manifold » Mon Dec 22, 2025 4:31 pm
Been a bit quiet recently. Still working on the convertible which needs a new battery. Looking to order one in the new year for that and some new spark plugs.
In the mean time Ive been doing a bit more collecting bits for the 'Midlander' Coupe EV. I needed to get an isabellenhutte shunt to measure energy outplut through the battery/inverter which couples nicely with the zombieverter (ended up getting the 500A one rather than the 1000A one, an RND (Reverse/Neutral/Drive) switch and some compression joints for between the inverter and rear outlander transaxle motor unit.
Postby manifold » Mon Dec 22, 2025 4:45 pm
Also recently received the zombieverter Vehicle control unit (VCU) off Damian on the Openinverter forum (https://openinverter.org/forum/) and a wiring loom off aliexpress.
I will be spending some time over Christmas getting to know the zombieinverter which can be accessed via a local webserver it presents via esp32 type chip with built in wifi and bluetooth.
First thing to do is fire it up, update the firmware then think about wiring in the dual channel throttle pedal. The reason for dual channels on the throttle is for redundancy. First off I bought a VAG circa 2014 SEAT pedal as a test. Not sure if this one will do but will give it a whirl. Reason for choosing this one is because it was quite small. Which will be a requirement in the Midas footwell. Apparently they are pretty standard across the VAG group of pedals but will soon find out. Otherwise I might be looking at prius or leaf pedals.
For info here is where I got the VCU: https://evbmw.com/index.php/evbmw-webshop/vcu-boards
Return to Engine conversions
