Clocks for Midas Mk2
Postby lankyjames » Wed Jun 01, 2011 9:49 am
Hey guys i need a working set of clocks / gauges for my mk2 midas.
The mileometer on the last 2 sets i have tried just do not work :(
Dash looks like this;
OR if you know what car they are from so i can go breakers yard trawling, would be good also!
thanks in advance,
Re: Clocks for Midas Mk2
Postby DavidL » Wed Jun 01, 2011 10:45 am
Austin Metro; MG Metro. Not sure about years of production, my Mk 2 used the instrument pack from a 1981 Austin Metro HLS (HLS and MG Metro had the rev counter in the dash, lower spec models didn't).
Hopefully someone more on-the-ball will be along soon with more information, though.
Postby WEBER45 » Wed Jun 01, 2011 12:45 pm
I have sone with rev counter from Mg metro mk1
Is the current unit from mk1 or 2 metro?
WEBER45
Postby mikeeskriett » Wed Jun 01, 2011 1:10 pm
The clocks are from a 1980 - 84 Metro any one will do but if you want a rev counter you'll need a set from one of the following... HLS, S, MG, MG Turbo (130mph) or Vanden Plas. If you have a version with the clock and the central fuel and temp sensors you can add the rev counter to that pod though one thing to check would be the circuit board on the back as some had the rev counter section trimmed off. There are two manufacturers of the instrument pods Smiths and Veglia the smiths are much better as the veglia ones tended to have pool voltage stablisation so your temp and fuel guages can be a bit wayward. You can tell the difference by looking at the rev counter as the smiths pod has a bevelled edge around the digital clock and the veglia is flat.
I'm now aware of how much of an anorak that makes me!!! :-p
Mike
Postby DavidL » Wed Jun 01, 2011 1:49 pm
mikeeskriett wrote:I'm now aware of how much of an anorak that makes me!!! :-p
Mike
I wouldn't worry, anoraks can be extremely useful!
(and I've just learnt something I never knew)
:D
Postby lankyjames » Tue Jun 14, 2011 12:36 pm
I have the clocks with a rev counter, well i have 2 sets, both of which the odometer has stopped working!
Time to start hunting i guess!
Postby mikeeskriett » Tue Jun 14, 2011 1:16 pm
That's a common issue tends to happen if they have been clocked or zero'd in the past or if someone has rammed the reset hard in the past. The good news is that the speedo is shared with the lower range models with the exception of the MG ones. The post 85 ones were particularly problematic.
The good news is they are available and not terrificly expensive.
http://cgi.ebay.co.uk/Speedometer-MPH-Austin-Metro-L-LE-Van-1984-/270760610725?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f0a970ba5
http://cgi.ebay.co.uk/MG-METRO-SPEEDOMETER-NEW-OLD-STOCK-BAU-4874-/320688369844?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4aaa8430b4
Just do a visual check as there are a couple of different speedo types depending on whether you have a Veglia, Smiths or later smiths unit. The smiths variations are with the downlighting over the instruments...single long green strip or three separate windows.
cheers,
Mike
Postby Geoff Butcher » Tue Jun 14, 2011 8:21 pm
I've never had one with a trip meter that worked :(
Postby mikeeskriett » Tue Jun 14, 2011 9:40 pm
I think the only one I ever had that worked was on my old Metro City. Then there are rev counters that need a thump to get them going!!
Return to Wanted
