Powder Coating Kit
Powder Coating Kit
Postby Rich » Wed Nov 25, 2009 6:10 pm
This year my Christmas present to myself was a powder coating machine from these guys http://www.electrostaticmagic.co.uk/, I saw them at the shows last year and again I stood and watched while he coated some steel plate on the stand on Saturday.
I'd been holding off buying one as I seemed to be doing ok with spray paints on the metal bits of the Midas while I rebuilt it, I wish I hadn't waited now as the finish you get with this gear is excellent. My first little project was the painted alloy rocker cover which seems to shed paint like there's no tomorrow, the results are near professional in appearance and the coating certainly seems tough.
On first impressions I'd recommend one of these to anyone needing to coat clean metal reliably.
Re: Powder Coating Kit
Postby manifold » Wed Nov 25, 2009 9:02 pm
looks quite good rich. will be interesting to see your results.
cheers,
david
Postby Geoff Butcher » Wed Nov 25, 2009 9:08 pm
Rich,
When painting your alloy rocker cover did you use etch primer?
Postby Rich » Wed Nov 25, 2009 9:17 pm
Geoff Butcher wrote:Rich,
Hi Geoff
Not when I used paint, I was painting over the existing finish. The powder coating requires a bare metal finish to start with.
Postby Rich » Wed Nov 25, 2009 9:40 pm
manifold wrote:looks quite good rich. will be interesting to see your results.
cheers,
david
I'll stick a pic up of the rocker cover if the weather holds off tomorrow.
Postby Rich » Thu Nov 26, 2009 7:20 pm
As requested, this is a textured black finish and I really like it. The imperfections you can see on the surface are water droplets I forgot to brush off before taking the pictures.
Postby Geoff Butcher » Thu Nov 26, 2009 9:00 pm
Looks good!
Return to General Chat
