MG Metro wheel
Re: MG Metro wheel
Postby Chris59 » Fri Dec 07, 2018 3:21 pm
Mmmmmmmh, you've got a point, it means that I may create a new problem if I use Metro 4 pots calipers instead of the standard Mini calipers, interesting….
Okay, I don't want to built a race car, this Mk2 will be mainly used for regularity rallies, so, do you think I should really go for 4 pots, or keep it as it is (ie standard post 84 Mini brakes) ?
Please keep in mind I can do what I want, as I have a set (or more) of each : Mini brakes and Metro brakes, vented or not.
So, your advice please guys ;)
Chris59
Re: MG Metro wheel
Postby Stuart » Fri Dec 07, 2018 5:18 pm
This car has vented Metro front brakes, the wheels are K&N Meteor 5" wide with 165/60x12 tyres.
Picture 047.jpg (1.57 MiB) Viewed 2798 times
Re: MG Metro wheel
Postby Chris59 » Fri Dec 07, 2018 7:41 pm
Well, Stuart, your picture is the best reply I could hope, many thanks !
So, let's go for it, Metro 4 pots brakes with Stainless steel pistons, vented discs and NOS pads.
Chris59
Re: MG Metro wheel
Postby Stuart » Fri Dec 07, 2018 8:55 pm
I didn't drive the car much, but I fitted some cheap black EBC pads and they had far more bite than the standard Austin/Rover Ferodo pads.
IMG_0527_edited (1) - Copy.jpg (225.47 KiB) Viewed 2786 times
Return to Mk 2
