Hans Efde wrote:I am puzzled by this problem. It is a very simple system. Logically it can only be:
a) the battery, check voltage drop during starting, use a charger to make sure it's capacity is full
b) the coil, this one is difficult to check, I have a spare, a blue Bosch. But it seems many types exist and I seem to have the wrong one concerning resistance. It gets extremely hot within a few miles and then cuts out. When cooled down it works again. For the moment I have my Aldon firestarter again in.
c) the distributor and module. The Lucas module is also a pain, since it's difficult to check. If you can find an old mechanical dizzy for troubleshooting, that would make life easier.
d) wiring. Problems can occur when a connection has a high resistance. F.e. during my starting attempts last year I found the solenoid of the starter motor smoking/hot. I hadn't fastened the connection properly, causing a high resistance. Which eats amps and causes the heat build up. Therefore check all high power connections, battery, starter motor, coil.
Your hot coil sounds like a ballast coil on a 12v wiring system?
Thanks for the list of things to check, I believe its probably the electronic module on the distributor. Investigations continue.
a) battery > turns engine over quite freely and has plenty of juice.
b) coil I have just replaced, so hoping that isn't the fault, it's definitely the correct type (12v no ballast)
c) hard to test, I did have the issue mentioned on facebook regarding the top-end revs cutting flat - which is incidentally the last time the car drove....and I have had issues with it cutting out before very recently, there may be a pattern here!
d) wiring is another thing I will need to have a poke around, I need to replace the earth cable but that is just my nit-picking
