hi all, i,ve manage to loose the collars that go over the tophat bolts(front subframe)
does anyone know the sizing on these so i can replace them,or if theres any other fix i can do cheers
l_jonez wrote:I'd be interested in seeing a diagram/picture as mine just had the standard mini set up
chad123 wrote:l_jonez wrote:I'd be interested in seeing a diagram/picture as mine just had the standard mini set up
how did you get your bolts to torque as mine just keep winding and squashing the top poly bush
Jvr19630 wrote:I thought the spacer goes over the threaded part of the tower bolt as this is the point the torque is created as this locks to the subframe. The Midas bulkhead is thicker so it needs the spacer.
