Quick shift gear lever
Re: Quick shift gear lever
Postby Rich » Thu Apr 21, 2016 10:10 am
Geoff Butcher wrote:In my car the gear lever is nowhere near the dash when in third. Wonder what the difference is?
The shift on the kit is supposed to be extended, presumably to avoid these issues. Mine is still standard length, so gets close to the dash without the quick shift kit fitted.
Postby Stuart » Thu Apr 21, 2016 2:37 pm
The MK3 was designed to require 62 mm added to the length of the two rods, that still left the lever too far forward, bending the lever helped, that could be the difference.
Postby axshack » Fri Apr 29, 2016 2:33 am
fozzza wrote:Approximately how much travel is the gear stick reduced by. Thinking of getting one for my MK 2.
I would say a good 50% left to right, and 25% forward and back as an estimate.
Postby fozzza » Fri Apr 29, 2016 9:07 pm
Rich wrote:I'm guessing but would say 20-30%
axshack wrote:I would say a good 50% left to right, and 25% forward and back as an estimate.
Once again thanks for the info guys. its much appreciated.
