Instrument panel
Instrument panel
Postby axshack » Sat Aug 03, 2019 6:03 am
Hi all,
my MG instrument panel is showing signs of graceful degradation !!
I have no indication of fuel level (might be the sender though)
I have lost a segment of the digital clock.
and the odometer has occasional fits of not counting the distance covered when zeroised - a mechanical problem in the clock I suspect.
So generally, I think the time is fast approaching for me to sort it out;
I fancy a total revamp and was considering one of the electronic pods designed for motor bikes, that Car Builder solutions sell.
Has anybody tried this?
Alternatively, where can I get a replacement MG Metro instrument cluster ?
Dave
Re: Instrument panel
Postby Hans Efde » Sat Aug 03, 2019 8:17 am
Yes David Manifold has.
Postby Rich » Sat Aug 03, 2019 7:35 pm
I used one, easy enough to connect up, you just have to use the wiring diagram to pick the right wires. Had to be a little creative with the speed sender, using the rear hub in the end. Mine didn't have a fuel gauge option, so I still had to have a separate gauge.
Postby Rich » Sat Aug 03, 2019 7:39 pm
Koso RX2N from Digital Speedos incidentally. There is a much broader range now..
Postby Rich » Sat Aug 03, 2019 9:29 pm
Thinking about it, I may have a cluster knocking about, should be able to check through the week.
Postby axshack » Sat Aug 03, 2019 10:25 pm
thanks for the input guys.
Definitely doing a lot of research on these whizzy motorbike instrument panels, especially if I can fit one inside the MG casing !!
Dave
Postby Rich » Sun Aug 04, 2019 10:43 am
axshack wrote:thanks for the input guys.
Dave
The RX2 I used fits within the binnacle.
Postby axshack » Sun Aug 04, 2019 11:31 am
Thanks for that Rich
Postby johno » Fri Aug 09, 2019 7:11 pm
I have one, will stick a picture up when it stops raining and I can get in the garage.
johno
Postby axshack » Tue Sep 03, 2019 3:56 pm
I do like that...!!! :)
I now have binnacle envy :)
Users browsing this forum: Google [Bot] and 1 guest
