Front heated windscreen fitting
Postby Dawesy » Mon Mar 09, 2020 9:41 am
Into the final stages of my restoration of my Midas Gold and have some questions regarding the fitting of the front windscreen with the heater elements. Three questions if anyone can help
1. Do you need to seal the edges of glass with anything to stop moisture ingress?
2. Whats the easiest way to do it???
3. Where does the joint go - top or bottom (I can't remember!)?
I am using one of the seals that Alistair sold to the club
Dawesy
Re: Front heated windscreen fitting
Postby fozzza » Mon Mar 09, 2020 11:38 am
Hi Dawesy.
I have got to fit a heated front screen to my Mk3 that I'm also restoring. To answer your questions, yes you do have to seal the edges of the screen. I will be fitting mine in the warmer weather when the seal will be a bit more flexible using the cord method. The join is half way down one of the sides and the locking strip on the opposite side, well that's how it was on my Mk3 and also my Mk2 that I had new from the Corby factory.
Speaking with Alistair there is no easy method to fit the screen but because of the moulded in dashboard on the Mk3 he suggested getting the bottom of the screen fitted in place first and good luck from there on. It's a job that I'm not relishing.
Postby midasnut » Mon Mar 09, 2020 11:34 pm
I cheated with my mk3 when I had it. The guy from car glass NE came to the house and replaced the perished seal with the one new one I had. From memory it was quite cheap, well cheaper than another screen. It might be worth giving your local branch a call.
midasnut
Postby ACourtney » Tue Mar 10, 2020 10:28 am
In answer to your questions:
1. Yes, it is sensible to seal the edges of the glass to stop moisture ingress. Before fitting it is worth priming the edges of the glass and laminate with a windscreen primer, such as 3M Windscreen Primer. SIKA 207, or Totalseal Universal Glass and Windscreen Primer. Then use a flexible, non-silicone, windscreen sealant in the seal - it is worth putting the sealant into the base of the groove of the rubber on both the body side and the glass side before fitting.
2. The easiest way is to get a professional to fit it for you, as Midasnut suggests. You will find any local windscreen fitter should be happy to fit the screen - they make more money fitting a screen than supplying one. If you do want to fit it yourself, I think on the Mk3 that rather than the cord method I would try the seal-on-first method. This is where you start by fitting the seal to the body and then work the glass into the seal. You start by working one bottom corner in and then running along the bottom edge, up the sides and finish along the top. I have seen You-tube videos where people use screwdrivers to prise the seal over the glass, that seems rather risky to me. I have a set of plastic wedges and levers that are sold for removing trim on production cars and these are safer tools to use than metal ones. The issue with the Mk3 is that the bonded in dash makes access to the lower edge of the glass and seal very difficult and that is why I think that the seal-on-first method would be better.
3. As Roy said, it is more usual to place the join to the side. More importantly it is worth cutting the seal slightly over length - say 1/8", 3mm - to allow for the rubber shrinking over time as it dries in the sun. The extra length should compress into place okay between the body and the screen.
The best lubricant for keeping the rubber fresh and stopping it shrinking is Silicone grease, or oil. However, if you ever need to paint your car in the future this will cause issues for the paint shop as the silicone gets into the pores of the gelcoat and is very difficult to remove, so you may wish to avoid that. I have read comments suggesting using vaseline, but I would suggest avoiding that, or any other petroleum based product, as whilst it may freshen up an old rubber seal for a short period, long term it is going to degrade the rubber faster. I have also heard of using olive oil, or other vegetable oils, and these are less likely to degrade the rubber whilst being easier for a paint shop to clean away. Red rubber grease is a vegetable oil based grease (with a good strong castor oil smell!), so that might be worth a go.
Postby Dawesy » Fri Mar 20, 2020 4:06 pm
Thank you for your replies. I am guessing that you need to notch the inside of the seal in order to get the wires into the cockpit.
Does you have any idea of the current draw when it is switched on?
Dawesy
Postby Geoff Butcher » Mon Mar 30, 2020 9:42 pm
I reckon it's money well spent to have a proper man where screens are concerned . I 've had the same people change the one on my Mk3 twice and they make it look easy, at least compared with how I make it look! :lol: When they changed the screen on my Ginetta they took a photo of it to pin on their wall,,, :P
