Headlamp covers
Re: Headlamp covers
Postby axshack » Thu Dec 04, 2014 8:31 pm
Rich wrote:
axshack wrote:as it happens today a car reversed into me and smashed the nearside 5.75inch lamp...so I now understand how it works...and luckily enough managed to get a CIBIE replacement at LARKSPEED for a helluva lot less than DEMON TWEEKS wanted !!
Good grief, is Larkspeed still going? I haven't heard of them since they shut the shop in Cleckheaton.
sure are:
http://www.larkspeed.com/index.pl?p=8482369&a=i
Re: Headlamp covers
Postby All That Glisters » Fri Dec 05, 2014 9:47 pm
I forgot to mention, when you remove old (rusted reflector) headlamps, don't throw them away because you can reuse the glass if your new one should get broken by a stone. Just cut the sealant between glass and reflector bowl and seal the good glass onto the good bowl. I use ordinary clear kitchen sealant but I suspect any adhesive will work.
Regards Mark
All That Glisters
Re: Headlamp covers
Postby axshack » Sat Dec 13, 2014 7:23 am
Good tip, many thanks :)
Re: Headlamp covers
Postby axshack » Thu Dec 18, 2014 5:59 pm
axshack wrote:
All That Glisters wrote:If you loop shoelaces or bits of string through the rings at the end of the springs and pull apart gently (you need three hands to do this) you can create a big enough gap to pop the lens into place without having to resort to screwdrivers.
Regards Mark
Hi Mark, many thanks for this hint! makes a lot sense now you have said that !! :D
Dave
Your are right!@ It works@ But what a faff @!@!
