by Rich » Sat Feb 05, 2011 1:19 am
I've had issues with the brakes, initially the long travel which I 'cured' with a cap on the rod in the servo, unfortunately even on the thinnest the brakes would bind on after about 10 miles. I ended up spacing out the alloy pedal pads to reasonable effect.
More recently I've had the ever diminishing bite point which reached it's natural conclusion over winter with a complete failure of the master cylinder. No leaks or anything like that, and the seals appeared good when I took it apart. After rebuilding with a Bigg Red kit I had a pedal again but was having to pump the brakes, it turned out one of the hub nuts had slackened off and the resulting (imperceptible) wobble was knocking the pads back. I only found this when it loosened enough to cause driveline noise.
Next plan is to build a twin cylinder set up that will allow me to dial out and slack without binding the brakes..
