Rear dampers
Re: Rear dampers
Postby manifold » Fri Jul 25, 2014 12:59 pm
Sounds like yours are the early ones David. The later ones are bits of plate with a threaded square bar in the middle. Them there was the lovely ones Alan and Stuart conceived. Personally I think there's is the best.
Re: Rear dampers
Postby DavidL » Fri Jul 25, 2014 3:40 pm
manifold wrote:Sounds like yours are the early ones David. The later ones are bits of plate with a threaded square bar in the middle. Them there was the lovely ones Alan and Stuart conceived. Personally I think there's is the best.
Mine could well have been on the car when it was built in January 1989 - does that help to identify them?
Are the second version you mention the ones that came from GTM? I hadn't heard of Alan and Stuart's version - unless those are the simple extended stub-axle type...
I've recently obtained a couple from Alistair which his suppliers had welded up incorrectly, and I still have to try and split them and re-weld, but work has once more intervened, so they are way down on my current to-do list.
Re: Rear dampers
Postby manifold » Fri Jul 25, 2014 8:19 pm
Yes Alans and Stuarts are the stubs. Lovely solution to the problem I think.
Yes '89 sounds like early ones.
Re: Rear dampers
Postby Geoff Butcher » Tue Sep 02, 2014 9:23 pm
Are my damper brackets the original ones? I know they're not Charlie's, but if they're original they've survived a huge mileage...
Re: Rear dampers
Postby DavidL » Wed Sep 03, 2014 12:54 am
Geoff Butcher wrote:Image
I'm not completely sure, but I think those could be GTM ones.
Re: Rear dampers
Postby manifold » Wed Sep 03, 2014 8:32 am
Yes they are gtm ones
Re: Rear dampers
Postby Hans Efde » Wed Sep 03, 2014 10:45 am
These are the best brackets, far superior over the original Midas ones (can't comment on Charlie's brackets since I have never seen them). It's a shame to let them rot because you won't find new ones and they look complicated to make. I gave mine some TLC a few years ago:
Re: Rear dampers
Postby Geoff Butcher » Sun Sep 07, 2014 4:00 pm
Could someone please measure the rear ground clearance, ground to wheelarch? Ta very much
Re: Rear dampers
Postby Hans Efde » Sun Sep 07, 2014 7:48 pm
Mine 56.5cm with 175/50 tyres.
Re: Rear dampers
Postby Geoff Butcher » Sun Sep 07, 2014 11:29 pm
Thanks Hans. Anyone else?
Users browsing this forum: No registered users and 12 guests
