what kind of thread and pitch brake lines
Postby ilmung » Wed Jul 08, 2015 8:31 pm
Hi
Can anybody help me with the kind of thread ( metric or Uk ) and the pitch of the thread of the brake lines metro 4 pots vented ?
regards
geert
ilmung
Re: what kind of thread and pitch brake lines
Postby ACourtney » Thu Jul 09, 2015 8:43 am
The Metro used metric threads on everything, except for the A-series engine (which was already a confusing mixture of UNF and UNC fittings). Your best bet is to buy a set of brake lines specifically made for the MG Metro. A set of stainless braided PTFE brake lines, such as Goodridge, Earls, or HEL, can work out to be not a lot more than buying the OEM spec pipes individually.
Just make sure you get a set that is for the MG Metro and not the Mini conversion set for MG Metro calipers, as these are metric at the caliper end and imperial at the body end.
Postby ilmung » Thu Jul 09, 2015 2:07 pm
http://www.ebay.co.uk/itm/AUSTIN-ROVER- ... 0922618636?
I bought on ebay this item , hope it's works :)
ilmung
Postby Hans Efde » Thu Jul 09, 2015 2:18 pm
These should be the correct hoses.
