Hi all.
Not after any advice this time, just a quick report on pumping up the hydragas using an (apparently home made) pump from ebay.
My new Midas was flat as a pancake at the back and the driver's side wheel was very occasionally catching on the wheel arch while cornering mildly on a bumpy surface. Looking at the wheel arch it was quite clear that this was not a new phenomenon and that the previous owner had been cornering with a little more enthusiasm than I had. Obviously this situation couldn't continue.
Trying to find garages that refilled hydragas in the local area rapidly demonstrated that there are few and most of them were either mythical, less than enthusiastic or quite expensive. Looking on ebay for a pump revealed this chap:
http://www.ebay.co.uk/itm/180858613818? ... 1439.l2649
The pump looked a bit Heath Robinson, but the feedback made it pretty clear that it worked, so I let the moths out of my wallet and bought one. It arrived today and turned out to be a very solidly made bit of kit that, while basic, is extremely well designed and works absolutely perfectly.
So, between April showers, I followed the extremely clear instructions (that had even more clearly been written by someone who has listened to feedback to try to produce instructions that are both foolproof and prepare the user for common problems). As they were so good and I know I am an ingenious fool, I almost followed them to the letter...
Everything went swimmingly until I got to the actual pumping stage and sat there, with the wheel in the air, cautiously pumping away while nothing (apparently) happened. After a rather a lot of pumps I went back to the instructions to notice the bit about putting all the wheels on the ground to get the height right.
There's nothing quite like the cold shower feeling of the sudden realisation that I hadn't followed the instructions - with predictably hilarious consequences.
I let the jack down and the car settled with the ride height quite high, but not as high as I had feared. Going back to the instructions I noticed that they also said that the pump only moved a small amount of fluid so to be patient. Fortunately my two gaffes cancelled out! After bouncing it about a bit and having a restorative cup of tea it seemed to have settled a little and so I took it out for a bit of a test drive.
It's a transformation - at least half the clunks and rattles have simply disappeared for a start! Even with only the back done, the car settles into corners calmly and is not remotely perturbed by bumps any more. throwing her moderately gently around a local roundabout system revealed that everything is much more composed and the rear wheels really do feel like they are pushing back; the effect inspires a degree of confidence that I haven't felt before. I have read in several places that the Gold 'corners like a go-cart'. Well, prior to pumping up the suspension that is precisely what it did - it was very stiff and very flat and you felt every thing about the surface. More to the point, just like a go-cart the wheels tended to skip over bumps and step out. I'll be honest, I assumed that the 'go-cart' description was basically true and that this was the nature of the car. However, whoever says it is like a go-cart is very wrong. Certainly it handles extremely well, but it does it without the coarseness you expect from a go-cart. So, if your Midas really handles like a go-cart then perhaps it's time to see to the fluid in the hydragas.
I still can't quite believe the difference! As a bonus, on my return, I noticed that the back end seems to have settled down to pretty well precisely the height I was aiming for. You couldn't really ask for more.
I hope this is helpful. any comments would be gratefully received.
