by Moneypit » Sat Apr 06, 2013 11:20 pm
It's my Midas we're talking about here. It's not a ' clunk' as such, nothing hard up against anything. It's more like a pre-ignition, a feeling ...if that makes any sense!It will turn over then a sort of choked chug!?? Almost like low battery.
I've stripped the carb, replaced the rotor arm and ignition/amplifier module on the side of the dizzy. I've stripped the startor motor...it was mucky inside but the brushes are a good length and it works fine on a bench test.It's a pre-engaged type starter and all appears to work well with the solenoid.The solenoid by itself though, can rattle in and out when volts across it, so I was thinking possibly poor contacts under the plunger.Also brand new, fully charged battery.
I put a coil on it from my sprint engined Latham. It's a cold start coil ( does this man it should be in a ballast resistor ignition and so only run off 9volts?) and the car starts 8 times out of 10. I put the new coil back on and problems again.I presume the metro system is not a ballasted one as there is supposed to be (and is )12volts at the +ve coil terminal when the ignition is on.If so ,I also presume that this is why I'm getting a better spark with the 'cold start 'coil even though this will probably kill it.
I'm still hoping it's the starter motor taking too much juice but don't have a spare to try. I was hoping to use two batteries, one for the starter and one for the solenoid and ignition.If this works, it will at least show it as ignition problem rather than anything else.
As for the ring gear....i've had the engine spinning without the ht lead connected and it spins fine with no symptoms.
