engine removal
engine removal
Postby goldeneye » Wed Feb 28, 2018 4:12 pm
Our trip last summer to Italia was very nice, but not for the engine :shock:
I have to remove it from the car to check it.
When i put the engine in, i did it with the subframe and lower the car on it. But is it possibly with a MK2 to get the engine out from the top? With the clutch on it?
It will save some work!
Midas Mk II
goldeneye
Re: engine removal
Postby fozzza » Wed Feb 28, 2018 7:28 pm
Yes it is possible but a bit of a squeeze, I did it with my MK2 but you need to remove the clutch cover. I also removed the alternator, starter motor and oil filter housing to give me more clearance.
Re: engine removal
Postby goldeneye » Mon Mar 05, 2018 11:32 am
Thanks, we will try it that way then :-)
Midas Mk II
goldeneye
