...for the want of a better title.
My gearchange was very loose and sloppy, but I've found out why, although I still need some info...
I found that
(a) the alloy cup which the gear lever's ball sits in (which is attached by rollpins to the main moving rod to the gearbox, and to a short tail going into the back of the alloy case) had become a loose fit on the long rod,
(b) the long (moving) rod had worn both itself and the bush it passes through at the front of the alloy case until there was about 2 to 3mm of slop, up, down, left, and right,
(c) the bolt which joins the forked end of the fixed rod to the gearbox is a very loose fit (in the tail of the gearbox). The bolt itself isn't worn enough to account for this.
(a) and (b) are problems I have managed to cure using new or newer parts, but (c) remains. I can't remember how this goes together - I presume there should be a rubber bush mounted in the gearbox hole which the bolt is a close fit in, but the last time I took one of these apart was about 20 years ago.
Can anyone remind me?
Sorry if this is in the wrong section, I suppose this section is meant more for answers than questions - please can someone move it if that's the case!
