Does this look knackered to you?
Postby Jin » Sat Oct 25, 2014 12:47 am
K series left hand engine mount looking from the wheel arch, i have no point of reference but it don't look too clever
Re: Does this look knackered to you?
Postby Rich » Sat Oct 25, 2014 9:49 am
Just looked at the one on the GTM, the alloy section in the middle should be centralised between the rubbers, so no, yours doesn't look too clever.
Postby Jin » Sat Oct 25, 2014 11:02 am
Arse :(
Thanks mate
Much appreciated ;)
Postby b1zbaz » Sat Oct 25, 2014 6:46 pm
That's fooked
Postby Jin » Sat Oct 25, 2014 9:34 pm
Does explain 1 of the many clonking noises I hear on a daily basis
Anyone got a spare in any condition?
Worse case scenario I can use it as a pattern
Postby Jin » Mon Oct 27, 2014 12:46 am
New mounts are rather rare and over a hundred quid !!!!
So until i get round to fabricating a new one I've bodged it by jacking it up and trashing a piece of hard 8mm thick rubber that's super glued to a piece of 3mm ally filed to a taper into the void, hopefully it will hold out.
Actually on some forums I've read regarding this recently this would be considered an upgrade? :D
Postby Rich » Mon Oct 27, 2014 9:17 am
http://www.ebay.co.uk/itm/ROVER-METRO-3-DOOR-1990-1998-1-1L-GEARBOX-MOUNT-/171091000092?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27d5d17b1c
That should be the one, I've used this supplier before and they are good, but call them first and just confirm it's the upper mount.
Postby Jin » Mon Oct 27, 2014 10:32 pm
Nice one, cheers, I'll see what they say
