Underbonnet insulation
Postby Geoff Butcher » Sat Dec 30, 2017 4:19 pm
My car has a layer of felt stuck on the inside of the bonnet and it''s now trying to fall off. When gluing it back I found it's saturated with water, not surprising, I suppose, given the four vents in the bonnet. Any suggestions for a more waterproof material, or should I just rip it all off and not bother?
Re: Underbonnet insulation
Postby johno » Sat Dec 30, 2017 4:27 pm
Woolies are the usual source of all things trim. Underbonnet stuff is usually there to reduce noise from the engine when you're stood next to the car. If it has a foil layer it helps with the heat insulation. High temp spray adhesive to fix.
https://www.woolies-trim.co.uk/category ... -deadening
johno
Return to Miscellaneous
