by axshack » Thu Mar 10, 2022 4:56 am
Recently my car was backed into which badly damaged the front bumper
The Cibie lamps were destroyed in the process, so I had to sort out replacements.
This is my solution: Cold air intake funnels with 60mm projector lamps inserted. This allows the air intake to continue to function and provides extra main beam lamps as before.
What do you think?
- IMG_0144.jpeg (122.72 KiB) Viewed 9458 times
by fozzza » Thu Mar 10, 2022 9:59 pm
Looks very smart Dave, and also complements your headlights. I also like your grill, so much better than the original one. Where did you get that made, I wouldn't mind one on my Mk3.
by axshack » Sat Mar 12, 2022 12:07 am
Hi Roy, I got the stainless steel chequer grille material from Car Builder Solutions (I think) and a mate welded the edging for me!
I also got the air intakes and projector lamps from them. They are my go to source of bits to keep my updating programme going !!
I will have a dig around because I am sure I have some of the chequer left over. I will let you know. You can have it if I can find it !!
by axshack » Fri Jul 01, 2022 4:20 pm
latest view of repair to the bumper.
I had to replace the Metro indicator lamps for something more modern (Thanks Hans for pointing that out)
As you can see still in primer as I still have to put a new gel coat on before taking it to the printshop
- IMG_0198.jpeg (217.8 KiB) Viewed 8010 times
by axshack » Fri Nov 03, 2023 3:03 pm
Hi folks, been MIA here for months, but now back among the living!!
My Gold is going to the wrappers later this month (at last) to finish the job off I will need either a pair of replacement MIDAS badges (front and rear) or a Vector graphic file that the wrappers can use to reproduce some badges.
Can anyone help?
Dave
