Decathlon coming alive
Re: Decathlon coming alive
Postby Stuart » Fri Jan 15, 2016 12:00 pm
goldeneye wrote:are 10" wheels not to small for a Midas?
Only if you've got 8.4" discs on. The one I've seen on tens looked fine, and the rolling diameter on the 10" is about the same as 12"
Postby Inim666 » Fri Jan 15, 2016 8:46 pm
They possibly are but I'm running 7.5 brakes off a 1275 gt so have the option should I want to try it and if I go low then they will fit great
Inim666
Postby Inim666 » Sat Sep 03, 2016 6:01 pm
Well it's more than alive its going Stanford hall next week too so be sure to look out for me on the gr8 minis stand although there are cosmetic bits to finish like carpets and door seals but it's road legal and that's what matters Imagehttps://flic.kr/p/Lp7sC7
Inim666
Postby Inim666 » Sat Sep 03, 2016 9:27 pm
Inim666
Postby streetsy » Sun Sep 04, 2016 6:30 am
I've booked a Midas OC stand if you would like to.join us.
Postby goldeneye » Sun Sep 04, 2016 7:05 pm
Looking good!
Midas Mk II
goldeneye
Postby Inim666 » Sun Sep 04, 2016 11:35 pm
Cheers folks I will be there at Stanford hall but will be with the gr8 mini team as they helped build and finish off the Midas plus the wife and daughter will be in her mini so ideally need to park with her. But rest assured I will come over and say hello
Inim666
Postby fozzza » Tue Sep 06, 2016 12:43 pm
Well done for getting another Midas on the road
Return to Mk 2
