manifold wrote:It might be worth putting a blow torch on the plugs to clean the crap off them if they have gone wet.
Blow torch the cylinders too with the plugs out. Stand back while doing it though lol. They will swoosh as the fuel burns off.
While the plugs are still warm from cleaning off refit them and try starting again.
Is there oil in the carb damper? Is float assembly and plunger working properly...not sticking and over fueling?
