I first of all cleaned up the rear loom as it had been inside a car which had been sat for 11 years. A wipe down with some white spirit made it much nicer to handle. The exposed end near the rear lights is not partcularly pretty, mainly due to the constant ingress of water. The connectors for the rear lights are poor (not usually a problem as they're easily replaced) but it's disconcerting when you try to pull them off and it brings half the (rusty) light fitting with it. There's also some butchering where the wires themselves have been cut a few inches before the connectors, then soldered back together badly and not insulated. I have no idea why this has been done, but in due course I will be replacing all the crimped connectors with proper soldered terminals and will re-solder and/or heatshrink the butchered bits. I will also remove the yellow tape and re-tape it.
Then there was the main loom to look at. This scared me a lot, so I took it round to see my good friend Mike. He is familiar with most aspects of car electrics and said he'd be happy to sort it out as I've been helping him with his Biota project. He spent the best part of two hours on his kitchen floor removing stuff that wasn't needed and identifying what wires did what. It is of course, second nature to him as he's been working with electrics since the age of 16, but to the untrained eye (like me!), the man is an utter genius. He has carefully unravelled things once I had discarded all the wrapping, old tape & plastic binding, then bunched all the wires together in the proper order with the minimum of electrical prior to further modification when in the car. I want to have the fusebox inside the car anyway, so this will happen in due course.
He also gave me distinct instructions to sort out yet more exposed soldering in the main loom. I have duly cut out said rubbish, resoldered and applied heatshrink. At least I did once I started using different solder to the cheap garbage that was in my new soldering kit... It seems the old stuff is definitely the best. And I didn't set the smoke alarms off, which pleased Mrs Bounce!
Rear loom, just after I cleaned all the old gunge off.
It holds such horrors as this...
..and this. Soldering iron's gonna get a lot of use.
The main loom. I kept pretending it wasn't there.
The Master at work.
All the junk taken out of the loom that wasn't needed. It's a lot.
Beautifully laid out and almost good to go. Modification, fusebox, new soldered terminals & wrapping to follow.
Butchered bits were re-soldered, and heatshrink applied.
