lankyjames wrote:Same files available here;
http://midasownersclub.co.uk/downloads/
Hans Efde wrote:Most are jpg, others are selfextracting .exe files. There are also autocad files, but not in the archive section. These should be visible with the normal window programs.
David L wrote:Hans Efde wrote:Most are jpg, others are selfextracting .exe files. There are also autocad files, but not in the archive section. These should be visible with the normal window programs.
There are three ".DWG" and three ".WMF" files. I believe ".DWG" files are CAD of some sort, which is why I can't open them. The ".WMF" seems to be Windows Metafile, I haven't tried to auto detect them yet.
(edit) Managed to open them with MS Office! Outline drawings of side view of the Gold coupe.
lankyjames wrote:David L wrote:Hans Efde wrote:Most are jpg, others are selfextracting .exe files. There are also autocad files, but not in the archive section. These should be visible with the normal window programs.
David, as you can open them, can you re-save them as a different file type, .doc etc and email them to me, I cannot seem to open them!
