Well the car passed, it failed on headlights and a track rod end. The headlights were working when I dropped it off and it turned out to be only a loose connector under the dash, track rod replaced but could possibly be the steering rack inducing play and if it comes to it will replace the subframe bushes front and back just because!
Also before the mot, as it was an advisory last year, I had the rear radius arms replaced along with the brake cylinders, shoes and wheel bearings while they were apart. I also had the car tuned before it went, as it was running like a dog, almost feels like this is the best place the car has been for a long while and there are still more bits to-do, small bits hopefully!
