I have decided where the dashboard will be modified. It's currently 120mm too wide and I have concluded that the side vents can go. It was either those or some very clever surgery on just the passenger side, and that would give me an offset centre console, not something I wanted at all. There is a separate piece that fits under the top of the dashboard which funnels air to the vents. This will need to be cut and sealed off due to there being no end vents. Saves a bit of weight I suppose! The cowling for the instruments may be slightly offset when it's finished (not by much I doubt) but given that the Mini dials couldn't be seen much either, I don't think it's going to matter too much. I have measured up where I will be cutting and also sorted the curvature of the top of the dashboard so it butts up nicely to the bottom of the windscreen. I knew there was a reason for keeping the original Midas dashtop rail!! Surgery will commence in due course.
Front end looking smoother (not that you can really tell...)
Door apertures looking healthier.
Rear end better, but the foglight holes still need sorting.
