I'm about to change my front shock absorbers, I haven't tried this before but know the access is somewhat challenging.
I'm thinking about using a core drill to make an access hole through each inner wing, probably about 2"/50mm diameter, about an inch/25mm up from the bottom surface of the inner box section. Has anyone else done this, or am I over-reacting to a job which needs to be done relatively infrequently?
