Gold/Mk 3 Rear brake cylinder size
Postby DavidL » Thu Jan 09, 2014 5:20 pm
What should it be?
After about 2 years of non-use, my rear brakes are seized on, even with the handbrake off, the drums won't turn.
The adjusters are seized and I've just ordered an adjuster spanner from Mini Spares, but I want to replace the rear cylinders while I'm at it and would like to know in advance what bore they should be. Currently it's the standard Metro braking system. Mini Spares have both 0.5" and 0.75" bore, but I'm sure there was once a 5/8" bore cylinder available too, possibly also other sizes.
Which should I go for?
Rimmer Bros only seem to offer one size, but the website doesn't say what size it is.
I know I'll be able to measure the old ones once they're off the car, but it's possible they may not be the correct size...
Re: Gold/Mk 3 Rear brake cylinder size
Postby Geoff Butcher » Thu Jan 09, 2014 9:35 pm
Hi, David,
Mine are 17.4mm, which I make 11/16"
Postby DavidL » Thu Jan 09, 2014 9:51 pm
Geoff Butcher wrote:Hi, David,
Hi Geoff, thanks. Hope you didn't have to strip your brakes down to tell me that! ;)
Are your brakes the standard Metro issue, otherwise?
Anyone know where I can get brake cylinders in 11/16" bore?
Postby midasnut » Fri Jan 10, 2014 6:46 pm
When I replaced mine about four years ago I just went into my local motor factors and asked for a pair of rear cylinders for a 1989 MG metro. I had them later the same day. it's worth a try.
midasnut
Postby Geoff Butcher » Fri Jan 10, 2014 9:20 pm
No, I've still got the last one I took off! They don't seem to last very long. Yes, my brakes are standard Metro at the moment - I got my new cylinders at my local factor.
Return to Miscellaneous
