All That Glisters wrote:David, I have looked at a Haynes Mini manual and a Mk1 Metro manual and neither of these show the springs that I have called "holding down springs". The Rover 100 manual calls them "Shoe Retainer Springs and Pins". I don't recall seeing them on any of the Minis or Metros or Midas's that I have owned, I'm not talking about the springs that pull the shoes towards each other and resist the hydraulic pistons, these are a pin that passes through a hole in the backplate and then through the rib of the brake shoe and is held by a short spring and a collet. I should have taken a photo but my whole attention was on liberating a handbrake bracket bolted to the back of the hub.
Anyway will you be at Moffatt this year?
Regards Mark
Hi Mark! The retaining pins I'm thinking of have a small protrusion either side of the tip. They go through the backplate and then through the midpoint of the shoe (through the rib), then a short coil spring fits over the pin, followed by what could be described as a collet, or a washer with a turned-up edge, which has a slotted hole in it where the protrusions on the tip of the pin pass through. The collet is then turned through 90 degrees to retain it on the pin. I can't remember a Mini or Metro rear brake which hasn't had them fitted, and that's on Minis from 1959 through 1975, and a couple of early 80s Metros.
I might be at Moffat, depending on what else I'm up to around the time. It's almost a certainty I won't be in the Midas, though. I just can't see me having the time to get it reassembled by then.
