7 port in a midas convertible
Postby ilmung » Fri Apr 24, 2015 8:51 am
does a A+ engine 1275 /1380 with a 7 port head fit in a Midas without doing big changes ?
ilmung
Re: 7 port in a midas convertible
Postby Stuart » Fri Apr 24, 2015 9:41 am
I guess it depends on the induction system used.
viewtopic.php?f=66&t=26
Postby ilmung » Sat Apr 25, 2015 11:59 am
What do you just mean with induction system ?
ilmung
Postby Stuart » Sat Apr 25, 2015 12:11 pm
ilmung wrote:What do you just mean with induction system ?
Sorry, the carburettors or fuel injection throttle bodies that you use, and the air filters. I think David's bonnet is dual-use, for two different cars, mainly to fit over his KAD twin-cam engine.
I imagine it'll be a tight squeeze with a standard bonnet and a 7 port, but the bonnet bulge may not need to be quite so big.
Postby Hans Efde » Sat Apr 25, 2015 2:03 pm
If you are going this route no doubt David can sell you a bonnet since he makes these by himself.
Postby ilmung » Sat Apr 25, 2015 6:04 pm
Hi Hans ,
Thanks for this info !
Can you give me the contact info of David ?
Geert
ilmung
Postby Hans Efde » Sat Apr 25, 2015 7:01 pm
ilmung wrote:Hi Hans ,
Geert
Hi Geert, you can contact David Manifold directly via PM. He set up this forum so is the second one in the list.
Postby Rich » Sat Apr 25, 2015 7:45 pm
The mould plug for this bonnet lives in my garage down here in Devon if that is any use to you.
Postby ilmung » Sat Apr 25, 2015 7:49 pm
Hi Rich
Do you mean you can make a bonnet for me ...... ???
Geert
ilmung
Postby DavidL » Sat Apr 25, 2015 9:12 pm
It's something I've also considered, although not in the near future.
I'm still undecided about which would be the best route to more engine fun, a 7 port head or one from a BMW K100 engine...
