rear hatch gas rams
rear hatch gas rams
Postby axshack » Wed Apr 29, 2015 3:53 pm
Hi all
has anybody managed to source a pair of gas rams that, when closed, do NOT constantly push against the glass i.e. the rams go into the low pressure zone?
At the moment I am struggling to keep the glass properly aligned in the hatch because of this constant pressure, which seems to be stronger on the offside, pushing the glass towards the rear.
I cannot be the first person to ask this question so hopefully there is a ready answer...apologies if there is a huge thread already, if so, please point me to it
Many thanks
Dave
Re: rear hatch gas rams
Postby Geoff Butcher » Wed Apr 29, 2015 8:23 pm
I've just replaced my 27-year-old struts with a pair from Gas Strut Engineering of Bedford. They're 80 Newtons and seem perfectly satisfactory.
Postby axshack » Wed Apr 29, 2015 9:41 pm
Geoff Butcher wrote:I've just replaced my 27-year-old struts with a pair from Gas Strut Engineering of Bedford. They're 80 Newtons and seem perfectly satisfactory.
thank you Geoff, as mine are the same vintage I guess I will do the same
I have discovered however that there is NO low pressure zone in the closed position, so maybe the originals are just a tad too strong?
Dave
Postby Geoff Butcher » Thu Apr 30, 2015 8:10 pm
I've heard of people using 130N, but 80N is plenty strong enough.
Postby Alan D. » Thu Apr 30, 2015 10:03 pm
Geoff Butcher wrote:I've heard of people using 130N, but 80N is plenty strong enough.
130 N!! you could use those as coil overs ( rear suspension)on a Midas as it has so little weight at the back!!!
Postby Stuart » Fri May 01, 2015 11:18 am
130 newtons is 29.2 pounds Alan.
Postby Alan D. » Fri May 01, 2015 7:56 pm
Stuart wrote:130 newtons is 29.2 pounds Alan.
Two a side would do!!!!
Postby axshack » Sat May 02, 2015 10:25 pm
I spoke to an expert from a company that makes gas rams for tailgates...and he told me that my view was incorrect !
gas rams do not have a low pressure zone when closed, in fact the pressure is at its highest when closed....no wonder our glass hatches are trying to creep downhill all the time.
80N rams are just strong enough to hold the hatch open, so I guess I am sticking with them...or cutting down the broom handle ! :)
Postby benofbrum » Sat May 02, 2015 11:36 pm
If the struts are only just strong enough in the warm weather, they may not be in the colder weather.
It's the Combined Gas Law: P1 x V1 over T1 equals P2 x V2 over T2 for a fixed volume of gas. I have had one or two older cars where the struts were OK in the warmer weather, but not quite in the winter.
benofbrum
Postby axshack » Thu May 21, 2015 10:04 am
interesting Ben....I think I will leave well alone !!
Now I have a sunroof fitted, I seem to be mostly glass above the waistline !! :D
Users browsing this forum: No registered users and 29 guests
