Hi guys
I'm nearly ready to get properly stuck into my Bronze rebuild but I'm in need of a few things to make the shell waterproof and proper again. The N/S door window winder mounting plate has rotten from the bottom and I need to either repair it or replace it. Anybody got one they can offer me before I get some sheet steel and find somewhere with a folding machine? The other query I have is relating to the rear hatch glass panel. The one I have seems to be cut from some other original item and it has been shaped wrong so it does not fit particularly well. It literally butts against the hinge on one side when I try to correctly line up the attachment bolts with the fittings.
Oh and I have one of those generic pop up and slide out sunroofs which, inevitably, leaks. The seals are way past their best so looking to replace those too. Anyone had any luck with this or just sourced a full replacement unit?
Cheers for any help in advance
Marc
