I've just acquired a Mk1 with a tuned engine, but it is misfiring at high revs. Is it now time for some fancy electronic distributor or ECU. If so which one do I get? The other problem I have with this car is when the car is ticking over there is a lot of vibration. The top engine steady has what looks like new orange Polybushes, I've not had time to check the lower engine mounts. The engine is not moving about, it seems solid enough, but I'm guessing the engine mounts are 36 years old, so it may be due for some new ones, again you A-series experts, is there anything clever I should be buying. The car has only done 27000 miles since 1981!
