This is probably last update before Stoneleigh and an important one at that if I want to attend in my MK2, to finish off the doors. I must admit this door hinge project has took a lot longer than first planned but hasn't been helped by the acquisition of my MK3.
With the door hinges removed I had to now try and take them apart without making a dogs dinner of them. As I had already mentioned I have the early type hinges where the hinge pin is fixed in the main body of the hinge and the outer part of the hinge rotates around the pin.
116 by
Roy Forrester, on Flickr
117 by
The problem was I was unsure how these hinges were made,
was the hinge pin fixed and part of the main body of the hinge (highly unlikely though) or was it 1 pin pressed in or 2 pins pressed in from either side, my gut feeling was 1 pin.
The first thing I did was to grind the heads on the captive bolts enough room for the 5/16 (8mm) pin to be removed. I now drilled the hinge pin from each end about 1/4" deep using a 5/16 drill, making sure I was perfectly central to the pin. I was now able to remove the outer part of the hinge. On closer inspection of the main body of the hinge I noticed a very slight chamfering in the bore which told me a pin had been inserted. I tried to press the remainder of the pin out but with no luck so I drilled all the way through with a 7mm drill, I thought if it was 2 separate pins from either side I would have to drill the main body of the hinge anyway.
Drilling the hole all the way through I found out it was 1 pin and it virtually dropped out on its own, so I carried out the same procedure on the other 3 hinges and was pleased I had stripped them all down without any casualties.
The hinge stripped apart with the hinge body drilled and tapped for the grease nipple.
118 by
I now had to decide how I was going to repair them, the problem with me is I always seem to over engineer jobs even if they are a relatively simple task. What I would like is to repair them in such a way that they are easily dismantled or perhaps able to remove the doors without unbolting the hinges which also evolves removing the dashboard, so removable pins was the answer. I decided to make the pins out of a bronze and hope they won't wear out too quickly.
119 by
The bronze pin inserted against the captive bolt to prevent the pin rotating.
120 by
M4 socket set screw used to prevent the hinge lifting out and to further lock the pin in place.
121 by
Hinges now had a few coats of paint.
122 by
123 by
The doors now fitted.
124 by
125 by
I'm now pleased to say the doors no longer drop and close a great deal better than they did.
