hi all
what size fitting is it required to fit the rear grease nipples?
also, since the mk3 etc do away with rear hydragas so presumably the retaining straps , how do they overcome the tendancy for the frame to droop in use unsupported?
can the rear subframe bush be replaced with a bolted matalastic item?
cheers
