I had to remove the bolts which hold the rear frame to the grp body because I wanted to renforce the grp body at that area .
But the holes in the grp are much bigger than the diameter of the bolts , is that a normal thing ?
ilmung wrote:Hhi Stuart , thanks for the reply !
I will take a look to the other side and if the holes are elongated in the same way ......
I am 1.75 m and 82 kg , is there a reason you need to know this
Yes the Midas MKII is mine , but it's also the car where I am working on , how did you know that could be my Midas ?
I have sold the Midas MKIII of Alan last year to a good friend , but I own anohter MKIII who was since +-2004 in Belgium on the road .
ilmung wrote:Is there any simple but accurate method to regulate the rear frame in width and height to the grp body ,
