Something I have been working on.....
Re: Something I have been working on.....
Postby manifold » Sat Nov 21, 2009 11:37 pm
Hi Jim,
Carl already does them rose jointed for the mini, albeit you would need to mount them to a simple beam. Pretty easy to make though for the midas.... straight box section with some ears on for the rose joint mounts.
Postby manifold » Sat Nov 21, 2009 11:42 pm
Geoff Butcher wrote:I think this car has evolved into a new species!
;) its going that way isnt it Geoff.
Main thing is that, except for the slight cut out for cam pulley and different bonnet, I haven't actually modified the body in any other way. That is the driving force for my ideas, to touch the body as little as possible as I still believe the car silloutte is as up to date as anything on the market now. The running gear is obviously a different story.
When looked at side on compared to the latest Nissan skyliner replacement, taking the headlamp caps away and its more or less the same lines, albeit shruken down.
Its my pocket battleship LOL.
Postby manifold » Tue Nov 24, 2009 11:52 pm
update:
Postby Stuart » Wed Nov 25, 2009 2:00 pm
Very nice, now you need a transparent body to show them off 8-)
Postby gooseman » Wed Nov 25, 2009 2:59 pm
NICE PIECES!!! They would even be nice in mild steel.....maybe ill get around to it one day....i can see them in square tube also...great pics david
gooseman
Postby manifold » Wed Nov 25, 2009 3:46 pm
No probs Jim.
If you want any dimensions let me know.
Eg, Using 1/2inch UNF for shock pickups and 3/8 rose joints .
Postby manifold » Sun Nov 29, 2009 6:27 pm
here you go Hans.
Sorry it was a bit dark but maybe you can do something with it with photoshop.
Ignore ride heights. I haven't set the suspension or put the motor back in yet.
Postby Hans Efde » Sun Nov 29, 2009 9:25 pm
Hi David,
Can you PM me the biggest possible files of these pics? The ones on the forum are too small to work on. I need pics of a few MB to be able to zoom in on the lights without losing too much resolution.
Cheers, Hans
Postby Hans Efde » Sun Dec 06, 2009 7:33 pm
If you would paint them white the light covers would more or less like this:
David lightswhitesmall.jpg (46.5 KiB) Viewed 5958 times
Postby manifold » Sun Dec 06, 2009 8:26 pm
looks great that Hans!
Looks pretty darn modern to me ;)
Return to General Chat
