by Alan D. » Tue Mar 02, 2010 7:07 pm
Hi Olof,
You need height adjustable coilover shockers, i.e. Gaz, Spax, etc.
I disagree with Stuart on the spring rate. I tried 140lbs and they were far too hard, they rattled my teeth. I then went down to 120's, again too hard. I think 90's or 100's would be about correct. He gave you good advice about the helper springs, I think that is essential on a Midas to fit two springs to the one coilover. A very soft spring say 40 or 60lbs and a normal rate of say 100 lbs. This way when the wheel falls into a pot hole, you do not get a severe bang on the suspension as the spring bottoms out, also you can achieve an initial soft spring rate, with the secondary harder spring coming into play as you get a little bit more enthusiastic!
![Picture6-1[1].jpg](./download/file.php?id=216&sid=345f7636da588b37aaee98ca6ca92292)
- Picture6-1[1].jpg (55.14 KiB) Viewed 4597 times
