our newly acquired midas gold has none working fuel and temp gauges - have replaced voltage stabiliser - still no readings - have read that to test gauges earth temp sender and should get max reading - no - nothing - tried same with fuel sender - no nothing ,
with ignition on get V reading of just under 10v at sender unit connection and nil with ignition off which to me suggests wiring between sender and gauge should be ok - making assumption that power comes via instrument pack to sender ??
if above is correct I suspect the gauges may be defective - does that seem likely and if so anyone know where they might be repaired or a source to replace them - not sure if they are replaceable as individual parts of instrument pack or whether it means replacing whole pack inc speedo and rev counter ,
if whole pack needed did they change between A series metro (on which my gold is based) and later metros - be glad of any wisdom from forum as struggling with this one at the moment
Paul
ps - in an ideal world I would want to plug an alternate instrument pack in as if gauges then worked would show me for sure that it is the gauges at fault
