by Hans Efde » Sun Jun 20, 2010 8:48 pm
Mine can be blistering hot when all air is out. But my expansion bottle is sitting too low, or the heater hose is too high, causing air to be trapped in that hose and than the heater doesn't do anything. I'll have to fix that.
Another thing I recall is that it's possible to have the fan connected the other way around, so it runs in the opposite direction. This will generate a small draft, but not very efficiently.
Also on the coupees, it helps to have the sunroof slightly opened. This creates suction and improves the heater flow.
Obviously it should be physically possible for the cabin air to flow to the vents besides the tail lights. So there should be vent holes in the back board and behind that holes in the side panels.
