note the numbering of the cam followers/buckets to ensure they are in the right wear holes.
these need to be shimmed to ensure they fit with the correct valve gap. a bit more arduous than on the 5 port as these have to be ground by hand and measured to fit.... times 16. Micrometers are handy here. If someone knows a faster well please tell!
To the right hand side you can see the weber alpha Throttle Position Sensor (TPS) which is used to measure the load factor to make the ignition 3D for the megajolt.
