rear coilover brackets for midas gold
Postby b1zbaz » Sun Mar 20, 2011 9:43 pm
i have stripped the rear suspension down and do not like the brackets for the coilovers to hub does anybody know if i can get my greasy mits on a better bracket as they look homemade and have cracks in the weld and are not even square i want something good as this car is for daily use and i like to throw cars about when i hit country roads
Re: rear coilover brackets for midas gold
Postby Hans Efde » Mon Mar 21, 2011 12:30 am
It looks like you are mentioning the first version of the Corby factory brackets.These were too thin and could break. Later version was made from sturdier steel. Both could be recognized by their rectangular design. GTM built a better version in a triangular shape. Here are mine:
rear suspension brackets.jpg (63.07 KiB) Viewed 11672 times
Postby manifold » Mon Mar 21, 2011 12:39 am
There are some intermediate ones as well. I had a set which I had, and recently sold. I had the GTM ones too, which are very good.
Current ones are better still...as in integrated in the arm and welded with Ti.
Postby b1zbaz » Mon Mar 21, 2011 8:18 pm
i cant see how they would go on or where the shocker bolts on
Postby manifold » Mon Mar 21, 2011 9:21 pm
A 3/8 bolt goes through the drilled square bar. I used a couple of old cylinder head studs. They did the trick fine. the other outer 3 areas (2 are out of view) bolt to the backplate, although in practice they need packing out with some small M8 washers.
Postby b1zbaz » Mon Mar 21, 2011 9:57 pm
hello davia where can i get them from i dont know anybodys number to order them but could do with them quite urgently really as the ones i have are terrible and possibly reckon mot failure
Postby b1zbaz » Mon Mar 21, 2011 10:08 pm
sorry that was meant to say david
Postby manifold » Mon Mar 21, 2011 10:32 pm
Thats a bit of a hard question. I just sold a set a month or two back.
Why not see if Alans got some of his super pins left over. I think his is the best mod.
Basically you take the arm off. Drive the stub axle off inward (that the wheel bearing fits to) and replace it with one of Alans kits which includes a mounting to pick up the shocker bottom pickup. I think they are the Rolls Royce/Dogs Danglies of suspension pickups for the Mk3 (bar my Ti ones ;) ). you will need the existing handbrake bracket as well.
I dont think Midas Cars/Alistair has the tooling for the rear suspension brackets anymore. Anyone please correct me if im wrong.
Hope that helps.
Postby Rich » Mon Mar 21, 2011 11:09 pm
I'm another one that could be interested in Alans pins.......
Postby Alan D. » Tue Mar 22, 2011 10:10 pm
